Air Suspension Relay
For those who don't speak dutch
Luke5turbo
Bericht door Luke5turbo » 03 dec 2019, 17:59
Hi. Can anyone tell me where the height safety cut off relay for the air suspension is located please?
Re: Air Suspension Relay
Bericht door Jack de zeeuw » 07 dec 2019, 00:42
The height safety cut off relay ??
I don't understand for what it is ?
Bericht door AS1 (Anne) » 08 dec 2019, 11:54
Not sure if there's a cut off relay (why not just a switch?) and if there is one, then it's likely inside the air suspension ECU box.
Luke5turbo
Bericht door Luke5turbo » 08 dec 2019, 17:20
Yes there is a safety cut off relay. The air suspension operates automatically but the relay is cutting off too early before the suspension reaches the correct height.
Bericht door Jack de zeeuw » 09 dec 2019, 01:42
Does he cut off the compressor or the complete electronic system ?
Luke5turbo
Bericht door Luke5turbo » 09 dec 2019, 12:39
It cuts off the compressor. The electronic system still works ok.
Bericht door Jack de zeeuw » 16 dec 2019, 01:32
Do you have a XR25 computer to check the system-warnings ?
Luke5turbo
Bericht door Luke5turbo » 16 dec 2019, 12:26
Yes it's showing the fault Height Not Reached.
