Air Suspension Relay
For those who don't speak dutch
Luke5turbo
Bericht door Luke5turbo »
Hi. Can anyone tell me where the height safety cut off relay for the air suspension is located please?
Re: Air Suspension Relay
The height safety cut off relay ??
I don't understand for what it is ?
Not sure if there's a cut off relay (why not just a switch?) and if there is one, then it's likely inside the air suspension ECU box.
Luke5turbo
Yes there is a safety cut off relay. The air suspension operates automatically but the relay is cutting off too early before the suspension reaches the correct height.
Does he cut off the compressor or the complete electronic system ?
Luke5turbo
It cuts off the compressor. The electronic system still works ok.
Do you have a XR25 computer to check the system-warnings ?
Luke5turbo
Yes it's showing the fault Height Not Reached.
