It moves again!
For those who don't speak dutch
Saffles
It moves again!
Bericht door Saffles »
It's taken 1.5 years to get to the bottom of the electrical fault but the car moves again under its own power!
I've taken it for a little drive around the car park today and got the brakes moving etc.
www.safrane.info
Email: Saffles@
2.5 20V Ph2
Nice!
But where's the proof? :wink:
Saffles
Lol I have none!
I might try to make a video with my camera..
www.safrane.info
Email: Saffles@
2.5 20V Ph2
5 years later......does it still move?
Saffles
Re: It moves again!
Not at the moment lol. It did.. but due to overheating the head gasket on the original engine had failed.
So Saffles being the man put in another engine :D
That overheated too :oops:
The second engine wasn't very reliable - I think i had it sat outside too long.. it would randomly start to cough and splutter but it had been a good engine when i removed it from another safrane i owned.
Anyway last time i started it the cooling system started working again :twisted: I had jacked it up the week before.. I think an airlock / bubble in the engine moved and made the sensor work properly... I went to restart it again a week later and it refused to start. Now the battery is dead... [smilie=ar.gif]
But I still have it!!! It's still out there.. I WILL get it running again.. somehow...
www.safrane.info
Email: Saffles@
2.5 20V Ph2
Re: It moves again!
Saffles schreef:
03 dec 2019, 11:34
I doubt the engine is the problem. It's probably something like a faulty cam shaft or crank shaft sensor.
Check for ruptured hoses. Did you already check the distributor cap?
Saffles
Re: It moves again!
Hi
I think it's either trapped air or a bad electrical connection. A ph1 owner asked me for photos of the fuel pipe. I jacked up the car very high to get these photos.
Then i put it down on the ground. The next time i started the car the cooling system ran properly - for over an hour!
Since then the car has refused to start (again). Now i want to empty the fuel tank and put new fuel into it.
Saffles.
www.safrane.info
Email: Saffles@
2.5 20V Ph2
